document-understanding
Document Understanding API guide
  • Getting Started
    • Overview
    • Limits and Quota
  • Examples Using the Document Understanding™ API
  • Licensing
  • Troubleshooting
Start the extraction fields request
Example of starting an extraction fields request via the Document Understanding API in Automation Suite, using the Project ID obtained from the Discovery Service.
Start extracting fields from a document
Tip:
The Project ID is obtained from the response received from the Get project information call.
curl -X 'POST' \
  'https://{fqdn}/<Organization_Name>/<Tenant_Name>/du_/api/framework/projects/<Project_ID>/extractors/invoices/extraction/start?api-version=1' \
  -H 'accept: text/plain' \
  -H 'Authorization: Bearer eyJhbGciO***CyAQu-qA' \
  -d '{
  "documentId": "25a03e48-cfe8-ed11-9f75-000d3a4964af"
curl -X 'POST' \
  -d '{
Response of extracting fields from a document
{ "operationId": "eee0a911-dfe8-ed11-907c-6045bd9d17d0" }
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
