- Getting started
- Authentication
- Scopes and permissions
- Platform Management APIs
Automation Suite API guide
Last updated Feb 24, 2025
Deletes multiple robot accounts from an organization, based on the organization ID.
DELETE https://{yourDomain}/{organizationName}/identity_/api/RobotAccount/{partitionGlobalId}--header 'Authorization: Bearer {access_token}'\
--header 'Content-Type: application/json'--header 'Authorization: Bearer {access_token}'\
--header 'Content-Type: application/json'Note: To obtain the
{access_token}, make sure to authenticate through one of the methods described here.
Path param |
Data type |
Description |
(required) |
String |
The ID of the organization you want to retrieve the robot accounts for. |
The request body contains the list of robot accounts IDs you want to bulk delete from the organization.
"robotAccountIDs": [
"string",
"string"
"string",
"string"
}Let's say you gathered all the information needed to build the API call.
- Your
{baseURL}is:https://{yourDomain}/{organizationName}/{tenantName}/ -
Your
{access_token}is:1234(for length considerations). - The
{partitionGlobalId}is:magic-7 -
The robot accounts you want to delete have the following IDs:
- Bot1:
11-xy - Bot2:
22-tz
- Bot1:
The call should resemble the following example (cURL):
curl --location --request DELETE 'https://{yourDomain}/{organizationName}/{tenantName}/identity_/api/RobotAccount/magic-7' \
--data-raw '{
"11-xy",
"22-tz"
}'curl --location --request DELETE 'https://{yourDomain}/{organizationName}/{tenantName}/identity_/api/RobotAccount/magic-7' \
--data-raw '{
"11-xy",
"22-tz"
