- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Migration options
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
You can enable and disable products in Automation Suite at any point post-installation.
input.json file and apply the new
configuration via uipathctl.Enabling or disabling Action Center
input.json file:
"actioncenter": {
"enabled": "true" //Set to "false" to disable the Action Center
}"actioncenter": {
}Enabling or disabling Apps
enable flag and an SQL database.
sql_connection_string_template_odbc in
input.json, then the default database name
is AutomationSuite_Apps.
sql_connection_str inside the Apps field. This overrides the default database and connection string template set in sql_connection_string_template_odbc.
input.json file:
"apps": {
"enabled": "true" //Set to "false" to disable the Apps
"sql_connection_str": "" ////Optional and only require to override the default database name
}"apps": {
}Enabling or disabling AI Center
sql_connection_string_template_jdbc in
input.json, then the default AI Center
database name is AutomationSuite_AICenter.
sql_connection_str inside the AI Center field. This overrides the default database and connection string template set in sql_connection_string_template_jdbc.
input.json:"aicenter": {
"enabled": "true", //Set to "false" to disable the AICenter
"sql_connection_str": "" //Optional and only required to override the default database name
}"aicenter": {
}AI Center installed in Automation Suite on AKS/EKS cannot connect to an external Orchestrator.
Enabling or disabling Automation Hub
automation_hub section of the input.json file, set the enabled flag
to true:
"automation_hub": {
"enabled": "true" //Set to "false" to disable Automation Hub
"sql_connection_str": "" //Optional and only require to override the default database name
}"automation_hub": {
}enabled flag to false in the
automation_hub section of the input.json file.
Enabling or disabling Automation Ops
sql_connection_string_template in input.json, then the default database name for
Automation Ops is AutomationSuite_Platform.
sql_connection_str inside the Automation Ops field. This overrides the default database and connection string template set in sql_connection_string_template.
input.json:
"automation_ops": {
"enabled": "true", //Set to "false" to disable the Automation Ops
}"automation_ops": {
}Enabling or disabling Automation Suite Robots
Before enabling Automation Suite Robots, make sure you meet the requirements.
To enable Automation Suite Robots, take the following steps:
Enable the
asrobotsflag in thefile. If you want to enable package caching, make sure to properly configure theinput.jsonpackagecachingandpackagecachefolderflags as well.{ "asrobots": { "enabled": Boolean, "packagecaching": Boolean, "packagecachefolder": String } }{ "asrobots": { "enabled": Boolean, "packagecaching": Boolean, "packagecachefolder": String } }Parameter
Default value
packagecachingtrueWhen set totrue, robots use a local cache for package resolution.packagecachefolder/uipath_asrobots_package_cacheThe disk location on the serverless agent node where the packages are stored.
Note: Package caching optimizes your process runs and allows them to run faster. NuGet packages are fetched from the filesystem instead of being downloaded from the Internet/network. This requires an additional space of minimum 10GB and should be allocated to a folder on the host machine filesystem of the dedicated nodes. -
If you use a multi-node HA-ready production setup, you must configure a specialized agent node for Automation Suite Robots.
asrobots flag in the input.json file.
Enabling or disabling Data Service
sql_connection_string_template in input.json, then the default database name is
AutomationSuite_DataService.
sql_connection_str inside the Data Service field. This overrides the default database and connection string template set in sql_connection_string_template.
input.json:
"dataservice": {
"enabled": "true", //Set to "false" to disable the Data Service,
}"dataservice": {
}Enabling or disabling Document Understanding
is AutomationSuite_DU_Datamanager.
sql_connection_str inside the Document Understanding field. This overrides the default database and connection string template set in sql_connection_string_template_odbc.
input.json:
"documentunderstanding": {
"enabled": true,
"sql_connection_str": "***" // dotnet connection string,
"datamanager": {
"sql_connection_str": "***" // odbc connection string
"pyodbc_sql_connection_str": "***" // python sql connection string
}"documentunderstanding": {
"enabled": true,
"datamanager": {
}Enabling or disabling Insights
AutomationSuite_Insights.
sql_connection_str inside the Insights field. This overrides the default database and connection string template set in sql_connection_string_template.
enable_realtime_monitoring flag to true.
Insights has an optional SMTP configuration to enable receiving email notifications. For details, see Configuring input.json.
input.json:
"insights": {
"enabled": "true", //Set to "false" to disable the Insights,
"enable_realtime_monitoring": "false", //Set to "true" to enable Insights Real-time monitoring,
}"insights": {
}Enabling or disabling Orchestrator
orchestrator flag to true in
"orchestrator": {
"enabled": "true" //Set to "false" to disable Orchestrator
}"orchestrator": {
}orchestrator flag to false in
Enabling or disabling Process Mining
input.json file:
- Enable the
processminingflag. -
Configure the following connection string templates:
sql_connection_string_templatesql_connection_string_template_jdbcsql_connection_string_template_odbcsql_connection_string_template_sqlalchemy_pyodbc
Add a separate connection string for the second SQL Server:
"processmining": { "enabled": true, "sql_connection_str": "" // dotnet connection string "sqlalchemy_pyodbc_sql_connection_str": "", "warehouse": { "sql_connection_str": "", "sqlalchemy_pyodbc_sql_connection_str": "" } }"processmining": { "enabled": true, "sql_connection_str": "" // dotnet connection string "sqlalchemy_pyodbc_sql_connection_str": "", "warehouse": { "sql_connection_str": "", "sqlalchemy_pyodbc_sql_connection_str": "" } }
processmining flag.
Enabling or disabling Task Mining
enable flag and an SQL Database.
AutomationSuite_Task_Mining.
To change the name to something other than the default, you can update the sql_connection_str inside the Task Mining field to override the default database and connection string template set in sql_connection_string_template
Task Mining requires a few additional steps, including the provisioning of a dedicated agent node for AI-specific workloads.
input.json:
"task_mining": {
"enabled": "true", //Set to "false" to disable the Task Mining,
}"task_mining": {
}Un-tainting for workloads
If desired, the Task Mining node can be repurposed as an agent node. To accomplish this, run the following commands:
- Check an actual taint using
kubectl describe node task-mining_nodenamecommand. - Run the command
kubectl taint nodes task-mining_nodename task.mining/cpu=present:NoSchedule-. - Check taint has disappeared using
Enabling or disabling Test Manager
AutomationSuite_Test_Manager.
sql_connection_str inside the Test Manager field. This overrides the default database and connection string template set in sql_connection_string_template.
input.json:
"test_manager": {
"enabled": "true", //Set to "false" to disable the Test Manager,
}"test_manager": {
}input.json, run the following commands with the uipathctl installer to update the service configuration:
- Run the following command to get an output of what changes will be made to the cluster:
# uipathctl manifest apply --dry-run input.json --versions versions.json automationhub deleted (dry-run) platform updated (dry-run)# uipathctl manifest apply --dry-run input.json --versions versions.json automationhub deleted (dry-run) platform updated (dry-run) - To apply the changes on the cluster, run:
# uipathctl manifest apply input.json --log-level info --skip-helm# uipathctl manifest apply input.json --log-level info --skip-helm
- Step 1: Changing the product selection in the configuration file
- Enabling or disabling Action Center
- Enabling or disabling Apps
- Enabling or disabling AI Center
- Enabling or disabling Automation Hub
- Enabling or disabling Automation Ops
- Enabling or disabling Automation Suite Robots
- Enabling or disabling Data Service
- Enabling or disabling Document Understanding
- Enabling or disabling Insights
- Enabling or disabling Orchestrator
- Enabling or disabling Process Mining
- Enabling or disabling Task Mining
- Enabling or disabling Test Manager
- Step 2: Running the installer to update the new product configuration
