- Getting started
 - Host administration
 - Organizations
 - Authentication and security
 - Licensing
 - Tenants and services
 - Accounts and roles
 - External applications
 - Testing in your organization
 - Notifications
 - Logging
 - Troubleshooting
Automation Suite admin guide
System administrators, also known as host administrators, have the required privileges to configure all host-level settings, which apply for all your organizations and tenants.
After completing the installation, the admin user account is automatically provisioned which has system administrator privileges.
Where can I get the credentials?
admin, are available in the cluster_config.json file.
               You can use this account to log in to the host portal. If needed, with this account you can create additional system administrator accounts.
As a system administrators, you can change the details of another system administrator account, including the account password.
To edit account details of an existing system administrator account:
- Log in to the host portal with a system administrator account. The host portal opens.
 - Select Users. The Users page opens displaying the list of system administrators.
 - Select the Edit icon at the right end of the account row. The Edit User panel opens from the right of the window.
 - Edit the information as needed.
 - Select Save to apply your changes and close the panel.
As a system administrator, you can delete system administrator accounts to prohibit a user from accessing the host portals.
To remove a system administrator account:
 - Select the Delete icon at the right end of the account row.
 - In the confirmation dialog, select Delete to confirm the action.
The account is removed from the users list and can no longer log in to the host portal.
