- Getting started
- Host administration
- Organizations
- Tenants and services
- Authentication and security
- Licensing
- Accounts and roles
- External applications
- Notifications
- Logging
- Troubleshooting
Automation Suite admin guide
Email setup
link
Field |
Description |
SMTP Host |
The IP or Domain of the SMTP server. |
SMTP Domain |
Domain for the username, if SMTP server requires authentication. |
SMTP Port |
The SMTP port. For example, if you are using a Gmail account to send mail messages and Enable secure connection is selected, the port should be 587. Note that both ports 80 and 587 must be opened during installation for Enable secure connection to work. |
SMTP Username |
The username of the SMTP server, if it requires authentication. For example, if you are using Gmail, fill in this field with the email address to be used to send messages. Select the Use default credentials if you want to connect to the SMTP server without a username and password. |
SMTP Password |
The password for the email account specified in SMTP Username. Select the Use default credentials if you want to connect to the SMTP server without a username and password. |
Default From Address |
The email address from which to send system email messages. |
Default From Display Name |
A custom display name for the email address from which you send system notifications. |
