- Getting started
- Authentication
- Scopes and permissions
- Platform Management APIs
- Get All Robot Accounts
- Delete Robot Accounts
- Get Specific Robot Account
- Delete Specific Robot Account
- Create a New Robot Account
- Update Robot Account
OUT OF SUPPORT
Automation Suite API guide
Last updated Feb 24, 2025
Deletes the specified robot account in an organization, based on the organization and robot account ID.
DELETE
https://{yourDomain}/{organizationName}/identity_/api/RobotAccount/{partitionGlobalId}/{robotAccountId}
Note: To obtain the
{access_token}
, make sure to authenticate through one of the methods described here.
Path param |
Data type |
Description |
(required) |
String |
The ID of the organization you want to delete the robot accounts from. |
(required) |
String |
The ID of the robot account you want to delete. |
Let's say you gathered all the information needed to build the API call.
- Your
{baseURL}
is:https://{yourDomain}/{organizationName}/{tenantName}/
Your
{access_token}
is:1234
(for length considerations). - The
{partitionGlobalId}
is:magic-7
- The
{robotAccountId}
is:33-ab
The call should resemble the following example (cURL):
curl --location --request DELETE 'https://{yourDomain}/{organizationName}/{tenantName}/identity_/api/RobotAccount/magic-7/33-ab' \
