uipathctl reference guide
Last updated Nov 11, 2025
uipathctl cluster migration import
The command executes the migration from a source directory to a target cluster.
uipathctl cluster migration import [flags]uipathctl cluster migration import [flags]
Examples
        # Import the cluster state from local directory to cluster
        uipathctl cluster migration import        # Import the cluster state from local directory to cluster
Options
  -h, --help              help for import
      --versions string   path to versions file  -h, --help              help for import
      --timeout duration    timeout of the command (default 5h0m0s)      --context string      name of the kubeconfig context to use
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
