- Getting started
- Host administration
- Organizations
- Tenants and services
- Authentication and security
- Licensing
- Accounts and roles
- External applications
- Testing in your organization
- AI Trust Layer
- Notifications
- Logging
- Troubleshooting
Automation Suite admin guide
You can enable SSO using any identity provider that supports the SAML 2.0 authentication protocol.
Enabling SAML SSO is a multi-step process and you must complete the following configuration:
- Configure your identity provider to recognize the UiPath platform as a service provider.
- Configure the UiPath platform as a service provider to recognize and trust your identity provider.
- Provision users to your organization to allow them to log in with SSO using the SAML 2.0 protocol from your identity provider.
UiPath supports multiple identity providers.
In this section, we exemplify how to find the specific configuration and obtain the certificates for each of the following identity providers:
ADFS
Google
Okta
PingOne
A. Configuring ADFS
Configure a machine to support ADFS and make sure you have access to the ADFS Management software. Work with your system administrator if needed.
B. Configuring Google
C. Configuring Okta
D. Configuring PingOne
Automation Suite as a service provider that recognizes your identity provider:
- Log in to the
host portalas a system administrator. - Make sure that Host is selected at the top of the left pane and then select Security.
- Select Configure under SAML SSO and follow the instructions for the identity provider that you use:
- Select Save to save the changes and return to the previous page.
- Select the toggle to the left of SAML SSO to enable the integration.
- Restart the 'identity-service-api-*' pod. This is required after making any changes to external providers.
The following configuration is optional and is only required if you want to use one or both advanced security features.
Step 3.1. Custom mapping
ADFS, Google, and Okta all use the email address as a SAML attribute. This section handles custom SAML mapping based on either the user name or an external provider key.
The following parameters need to be set in the SAML SSO configuration in the Security page at the host level.
External user mapping strategy - Defines the mapping strategy. The following options are available:
By user email- Your email address is set as the attribute. This is the default value. -
By username- Your user name is set as the attribute. -
By external provider key- An external provider key is set as the attribute.
- External user identifier claim name - Defines the claim to be used as an identifier for the mapping. This is only required if you set your username as the attribute.
