automation-ops
- Release Notes
- Getting Started
- Governance
- Logging
OUT OF SUPPORT
Automation Ops User Guide for Automation Suite
Last updated Nov 11, 2024
General Workflow Analyzer Settings
link- Allow users to override - If enabled, users are allowed to make changes to Workflow Analyzer settings. This option is not enabled by default.
Referenced or embedded - Select how to define the settings for Workflow Analyzer rules and counters in the policy:
- Referenced - Define the settings using a JSON file configured similarly to the RuleConfig.json file. If you select this option, indicate the full path to the file in the Referenced Rules file box. The location must be accessible from the Studio machines.
- Embedded - Define the settings using the options on the policy page. This is the default option.
