- Release notes
 - Getting Started
 - Permissions
 - Starting as
 - Admin Console
 - Workspace
 - Explore
 - Share Idea or Automation
 - Dashboards
 - My Tasks
 - Notifications
 - Email Notifications
 - Resources
 - Studio Integration
 - Task Capture Integration
 - Automation Store
 - Additional Resources
Automation Hub User Guide
Last updated Apr 15, 2025
The Automation Store can be enabled and controlled via the settings we provide in both Automation CloudTM and Automation Hub.
As an Administrator that wants to set up the Store for rolling it out to the Business Users, here are the consolidated steps that you need to perform:
- Start by from Automation SuiteTM.
 - Decide how you want your users to interact with the Automations in the Store by checking the Instant consumption settings in Automation Hub.
 - The Store can be integrated with Orchestrator (Cloud), so check the details of the Orchestrator connection in Automation Hub.
 - The end goal is for your users to run the Automations from the Store in their UiPath Assistant, so check the minimum requirements for the Assistant setup and how to perform the connection.
