- Open API- Introduction to Automation Hub API
- API References
- Generate your Token from Automation Hub
- Input for Automation Pipeline
- Input for Submission Type
- Input for Phase
- Input for Status
- Input for Phase and Status Update
- Input for Business Unit
- Input for Applications
- Input for Category
- Input for Cost Benefit Analysis
- Input for High Level Assessment
- Input for Detailed Assessment
- Input for Automation Idea Creation Date
- Input for Users
- Input for User Status
- User Status Table
- Input for Collaborators
- Output Dictionary
- Automation Hub Open API Power Query Data Parsing
Automation Hub API Guide
Last updated Apr 19, 2024
Note:
         For both Automation Idea Creation Date and Automation Idea Update Date filters the used date format is EPOCH.
                  To convert your dates in EPOC format you can use this converter.
| Key | Value | Use Case |
| createdStart | The start date for the search. | GET filter |
| createdEnd | The end date for the search. | GET filter |
Examples:
               Retrieve all Automation Ideas created after 23/07/2020: createdStart=1595462400
               Retrieve all Automation Ideas created before 23/07/2020: createdEnd=1595462400
               Retrieve all Automation Ideas created between 22/07/2020 and 23/07/2020: CreatedStart=1595376000&createdEnd=1595462400
