Automation Hub User Guide
Last updated Oct 13, 2025
Audit Logs
By accessing the Audit Logs page the tenant's System Admin as well as other users with roles that have the permission to access the option, can view and download CSV reports containing information about the user activity on their Automation Hub tenant as well as Open API calls made.
The types of logs available in the Audit Logs section are:
  • Event Log - main report where you can find a list of all the events that happened, who performed them and time.
  • Open API - list of all the API calls performed on your Automation Hub Open API service - includes the entire request and response.
  • Tenant service - list of all the API calls performed on your Automation Hub instance - includes the entire request and response.
  • Object reference - list of API calls that too large to be displayed in the Tenant Service or Open API report.
To access the page go to Admin Console > Account -> Audit Logs.
Note: Audit Logs are stored for 60 days.
The table contains the following columns:
  • Service Name
  • Date Range
  • Size
  • Download button
  • View (button)
Service Name
Defines the type of service that the log is generated for.
Options:
Date Range
  • Represents the period for which the log is generated.
  • The logs are generated on a weekly basis - therefore the range will always be of 1 week.
  • The dates are generated by the system and cannot be controlled by the user.
Size
  • Represents the size of the log file expressed in kilobytes.
Download
  • The download button will be displayed in the “Download” column.
  • The button will allow the user to download the file and store it on his local machine.
  • The download button will not have limitations or restrictions - so the user can access and download the log at any time.
View
  • Will allow the user to visualize any of audit log report type from the page.
  • When clicked, it will open a table visualizer above the initial table that contains the Audit Log files.
  • Search will allow you to search in any column of the file.
  • Most common use case that we will recommend will be the search by “Action Name” in the Event Log report.
  • The visualizer also has pagination that enters into play after showing 210 lines of the report.
There are a couple of fields in the report which have also the option to copy the content of a specific field.
These fields are:
  • Action Info
  • Request Body
  • Response Body
  • Open API token
The response body and the request body are usually too large to show up in the visualizer. If that happens, they will show up like this {}
Event Log - Action Types
The list below is the complete list of events that can occur on tenant level and that can be included in the Action type:
Table 1. Event Log - Action types
Event Id
Platform Event Name
Platform Event Slug
1
Idea Submitted
idea-submitted
2
Process Phase and Status Changed
process-phase-changed
3
Process Mark As Completed
process-mark-completed
4
User Profile Updated
user-profile-updated
5
Process Updated
process-updated
6
Process Document Added
process-document-added
7
Process Followed
process-followed
8
Process Upvoted
process-upvoted
9
Process Comment Added
process-comment-added
10
Process Comment Reply Added
process-comment-reply-added
11
Process Comment User Mentioned
process-comment-user-mentioned
12
Process Collaborator Role Assigned
process-collaborator-role-assigned
13
Reusable Component Added
reusable-component-added
14
Process Abuse Reported
process-abuse-reported
15
Component Status Changed
component-status-changed
16
Component Support Requested
component-support-requested
17
Component Abuse Reported
component-abuse-reported
18
Email Verification Sent
email-verification-sent
19
Component Review Abuse Reported
component-review-abuse-reported
20
Process Comment Abuse Reported
process-abuse-comment-reported
21
Component Comment Abuse Reported
component-abuse-comment-reported
22
Process Collaborator Role Removed
process-collaborator-role-removed
23
Process Collaborator About Edit Rights Gran
process-collaborator-about-edit-rights-granted
24
Process Collaborator About Edit Rights Revo
process-collaborator-about-edit-rights-revoked
25
Process Owner Assigned
process-owner-assigned
26
Project Manager Assigned
project-manager-assigned
27
Process Document Updated
process-document-updated
28
Process Document Deleted
process-document-deleted
29
Admin Process Role Added
admin-process-role-added
30
Admin Process Role Updated
admin-process-role-updated
31
Admin Process Role Deleted
admin-process-role-deleted
32
Admin Template Document Added
admin-template-document-added
33
Admin Template Document Updated
admin-template-document-updated
34
Admin Template Document Set Default
admin-template-document-set-default
35
Admin Process Role Enabled
admin-process-role-enabled
36
Admin Process Role Disabled
admin-process-role-disabled
37
Admin Template Deleted
admin-template-deleted
38
Process Collaborator Documentation Edit Rights Granted
process-collaborator-documentation-edit-rights-granted
39
Process Collaborator Documentation Edit Rights Revoked
process-collaborator-documentation-edit-rights-revoked
40
Process Collaborator Removed From Certain Role Removed
process-collaborator-certain-role-removed
41
Component Version Updated
component-version-updated
42
Project Manager Role Assigned
project-manager-role-assigned
43
Component updated
component-updated
44
CoE-driven Idea Submitted
coe-driven-idea-submitted
45
Reusable component removed
reusable-component-removed
46
System Admin added to user
system-admin-added-to-user
47
Program Manager added to user
program-manager-added-to-user
48
Curator added to user
curator-added-to-user
49
Assigned System admin
assigned-system-admin
50
System Admin removed from user
system-admin-removed-from-user
51
Program Manager removed from user
program-manager-removed-from-user
52
Curator removed from user
curator-removed-from-user
53
Process hierarchy updated
process-hierarchy-updated
54
Application inventory updated
application-inventory-updated
55
User's information updated
admin-users-information-updated
56
Assigned Program Manager
assigned-program-manager
57
Assigned Curator
assigned-curator
58
Removed as System Admin
removed-as-system-admin
59
Removed as Program Manager
removed-as-program-manager
60
Removed as Curator
removed-as-curator
61
Component Archived
component-archived
62
Component Updated for Downloaded Users
component-updated-for-downloaded-users
63
Component Uploaded for Curation
component-uploaded-for-curation
64
Component Curation Started
component-curation-started
65
Component Curation Reject
component-curation-reject
66
Component Curation Needs Update
component-curation-needs-update
67
Component Curation Publish
component-curation-publish
68
Component Downloaded
component-downloaded
69
Component Review Added
component-review-added
70
Component Comment Added
component-comment-added
71
Component New Reply
component-new-reply
72
Component User Mentioned
component-user-mentioned
73
Authorized User added to user
authorized-user-added-to-user
74
CoE Collaborator added to user
coe-collaborator-added-to-user
75
Assigned Authorized User
assigned-authorized-user
76
Assigned CoE Collaborator
assigned-coe-collaborator
77
Authorized User removed from user
authorized-user-removed-from-user
78
CoE Collaborator removed from user
coe-collaborator-removed-from-user
79
Removed as Authorized User
removed-as-authorized-user
80
Removed as CoE Collaborator
removed-as-coe-collaborator
81
Error email to Account Owner
changed-plan-error-email
82
Process Collaborator CBA Edit Rights Grante
process-collaborator-cba-edit-rights-granted
83
User Sync Finished
user-sync-finished
84
User Deleted
user-deleted
85
Process Collaborator Components Edit Right
process-collaborator-components-edit-rights-granted
86
User Deactivated
user-deactivated
87
User Activated
user-activated
88
Component bug reported
component-bug-reported
89
CD Automation submitted
cd-automation-submitted
90
CD Automation shared
cd-automation-shared
91
CD Automation requested
cd-automation-requested
92
Automation Published
automation-published
93
Process Review Added
process-review-added
94
Process Question Added
process-question-added
95
Process Question Reply Added
process-question-reply-added
96
Process Review Updated
process-review-updated
97
Group Added
group-added
98
Group Deleted
group-deleted
99
Group Updated
group-updated
100
Automation Consumed
automation-consumed
101
User Added
user-added
102
User Updated
user-updated
103
User Mentioned In A Question
process-question-user-mentioned
104
User Login
log-in
105
User Logout
log-out
106
E-mail sent to the user
email-sent
107
Idea is deleted
delete-process
Exporting Audit Logs Information as a .CSV File
You can download and retain the logs for the company's specific audit requirements. Each row of the table contains a log file that can be downloaded locally in a CSV file by clicking the Download button.
Note: Each entry in the file contains details for one specific action captured by the log.
The entry contains the following fields:
Field
userEmail
the e-mail of the user who performed the operation
userId
the User ID as registered in the data base
logType
the type of log
auditLogRequestId
the ID of the log entry
timestamp
the timestamp registered for the log
tenantId
the tenant UUID
tenantName
the tenant name
statusCode
the status code of the API request
responseBody
  • if applicable
requestBody
  • if applicable
query
the query object
logRequestDuration
the duration of the log request
logEndEpoch
the end time of the log request
cloudUserId
  • if applicable
logStartEpoch
the start time of the epoch log
URL
the endpoint URL
serviceName
Differentiates between the different services:
  • tenant - service
  • open - API
method
API method
openAPIToken
filled only for open - API service logs
Sample
