- Release Notes
 - Getting Started
 - Permissions
 - Starting as
 - Admin Console
 - Workspace
 - Explore
 - Dashboards
 - Share Idea or Automation
 - My Tasks
 - Notifications
 - Email Notifications
 - Resources
 - Studio Integration
 - Task Capture Integration
 - Automation Store
 - Additional Resources
Automation Hub User Guide
UiPath Task Capture is a process discovery tool that helps you get detailed insights about automation candidates directly from your employees.
Working in the background, the tool captures the performed steps, takes screenshots with every mouse click, and collects smart data about the process statistics (execution time, number of steps, text entries, etc.). You can edit and annotate each screenshot and add information for each step.
For more details check out the Task Capture User Guide.
XAML that can be easily exported in Automation Hub.
            The Task Capture tool can be opened from the following Automation Hub locations:
The page displayed after an Employee-driven idea was submitted
This page contains the idea score and the option to document the submitted idea using Task Capture. The option is available for the idea submitter. Access the page to find out more.
The Documentation module under both the Idea and Automation Profile pages
The pages contain the documentation added to support the idea or automation submissions. The option to add documentation and use Task Capture for capturing processes is available only for the idea/automation submitter and users assigned with editing rights for the Documentation section.
Access the to find out more.
The Create New Process Document with Task Capture card is displayed in both of the above-mentioned locations.
Once you click Create you have the below options:
Open Task Capture
Click the Open Task Capture button from the pop-up window. The tool is displayed allowing you to start capturing the process needed to document your assessment.
In case the language set up in Automation Hub is different from the one in Task Capture, a message is displayed in Task Capture allowing you to switch the Task Capture language to the one set up in Automation Hub.
As soon as you captured the process follow the below steps in order to export it to Automation Hub:
- In Task Capture access Export & Publish and select Automation Hub.
 - The Uploading pop up page is displayed. The recorded
.ssp,.docx,.xamland.jpgfiles are compressed into aZIParchive and uploaded to Automation Hub > Idea/Automation Profile page > Documentation. -
                        A confirmation message is displayed once the
ZIParchive is uploaded. You have the following options:- Copy path - copy the Automation Hub location path of the
ZIParchive. - Open file - open the Automation Hub page where the process doc file is stored.
To open the attached documentation follow the steps below:
- Click the file card.
 - Click Download.
 - Select where you want to save the
ZIPfile and click Save. - Once the
ZIPis saved open it. -
                        The recorded process details are available in
.ssp,.docx,.xamland.jpgfiles.
Download
If you don't have Task Capture installed or if you have a version older than 20.4 please use the Download drop-down list to install the tool. The below options are available:
- x64 version
 - x32 version
 - MSI x64 version
 - MSI x64 version
Check the Download Task Capture page for the step by step information.
