- Release Notes
- Getting Started
- Permissions
- Starting as
- Admin Console
- Workspace
- Explore
- Dashboards
- Share Idea or Automation
- My Tasks
- Notifications
- Email Notifications
- Resources
- Studio Integration
- Task Capture Integration
- Automation Store
- Additional Resources
Automation Hub User Guide
Last updated Oct 17, 2024
After successfully logging in, you, as an Idea Approver should focus on the following tasks:
- check out the shared ideas by accessing the Workspace > Automation Pipeline > Review view and review the shared ideas.
- within the same page, check the list of ideas and identify any potential duplicates in order to facilitate the review process.
You are encouraged to Share your own ideas or components that will boost the company’s RPA assimilation.
By accessing the Explore module you can:
- view the ideas shared by your colleagues and choose to follow the ones that drow your attention,
- check out and download the components shared within your tenant,
- access the Leaderboard.
