- Getting Started
- Network requirements
- Single-node requirements and installation
- Multi-node requirements and installation
- Accessing AI Center
- Provision an AI Center tenant
- Updating Orchestrator and Identity Server certificates
- Resizing PVC
- Adding a new node to the cluster
- ML packages offline installation
- Configuring the Cluster
- Configuring the FQDN post-installation
- Backing up and Restoring the Cluster
- Using the Monitoring Stack
- Setting up a Kerberos Authentication
- Provisioning a GPU
- Using the configuration file
- Node scheduling
- Migration and Upgrade
- Basic Troubleshooting Guide
AI Center Installation Guide
Requirements
linkOverview
linkWhat you need | Requirements | Configuration | Installation |
One Linux machine (RHEL 8.2, 8.3, 8.4, 8.5) | Multi-node machine requirements | Configuring the machines | |
SQL Server (MS SQL 2016, 2017, 2019 - Enterprise and Standard) | - | Configuring MS SQL Server | - |
DNS | - | Configuring the DNS | - |
Load balancer | - | Configuring the load balancer | - |
Multi-node Machine Requirements
linkThis is the only configuration supported for production deployments.
Bundle |
Minimum |
Recommended |
Node count |
At least 3 server nodes. There must be an odd number of server nodes in a cluster to have increased fault tolerance Any number of agent nodes. |
(v-)CPU total |
48 (v-)CPU |
64 (v-)CPU |
Minimum (v-)CPU per node |
12 (v-)CPU |
16 (v-)CPU |
RAM total |
96 GiB |
144 GiB |
Cluster disk for each node |
256 GiB SSD Min IOPS: 1100 |
Data disk for each server node |
2 TiB SSD Min IOPS 1100 |
etcd disk for each server node |
16 GiB SSD Min IOPS: 240 |
UiPath Bundle Disk (For offline installation only, on the first server node) |
512 GiB SSD Min IOPS: 1100 |
Additional agent node with GPU support for Document Understanding
Bundle |
Requirement |
(v-)CPU |
8 (v-)CPU |
RAM |
52 GiB |
Cluster disk |
Data disk |
N/A |
GPU RAM |
11 GiB |
Advanced storage and compute requirements
Use |
CPU |
RAM (GiB) |
GPU |
Hardware usage right after install |
30 (for minimum configuration) 33 (for recommended configuration) |
48 |
0 |
Minimum for serving (ML Skill, one replica) |
0.6 |
2 |
0 |
Minimum for Training (Pipeline) |
1 |
4 |
0 |
Document Understanding model Serving (ML Skill, one replica) |
1 |
4 |
0 |
Document Understanding model Training |
2 |
24 |
1 |
