studio
- Getting Started
- Setup and Configuration
- Automation Projects
- Dependencies
- Types of Workflows
- Control Flow
- File Comparison
- Automation Best Practices
- Source Control Integration
- Debugging
- Logging
- The Diagnostic Tool
- Workflow Analyzer
- About Workflow Analyzer
- ST-DBP-023 - Empty Workflow
- ST-USG-032 - Required Tags
- Variables
- Arguments
- Imported Namespaces
- Coded automations
- Introduction
- Registering custom services
- Before and After contexts
- Generating code
- Invoking Code Source File
- Using Coded automation in Low-Code workflow
- Integrating Low-Code workflow in Coded automation
- Invoking Coded automation in another Coded automation
- Integrating OpenAI with Coded Workflows
- Apply for a loan with UiBank
- Queue generation with coded workflows and Orchestrator APIs
- Using imported library projects in coded automations
- Using two-factor authentication within coded automations
- Object Repository
- Extensions
- About extensions
- SetupExtensions tool
- Screen resolution settings
- Group Policies
- Multiple browser profiles
- Group Policy conflict
- Chrome Extension on Mac
- Group Policies
- List of extensions for Edge
- Extension for Safari
- SAP Solution Manager plugin
- Excel Add-in
- Studio testing
- Troubleshooting
- About troubleshooting
- Assembly compilation errors
- Microsoft Office issues
Studio user guide
Last updated May 5, 2026
This tutorial shows you how to invoke a coded automation within another coded automation. We demonstrate this by using a sample scenario where a coded workflow invokes the CodedResetAssetValue coded automation. The CodedResetAssetValue automation retrieves the values of an asset, compares them to an input value, and updates the asset in Orchestrator if the values are different. If the values are the same, it logs a message that the asset value remains unchanged.
- Use the
RunWorkflowmethod to invoke theCodedResetAssetValue.csfile, and provideDictionary <string, object>pairs as arguments.
In the dictionary, specify the values for the assetName and assetValue parameters.
For example, set assetName as "MyAsset" and assetValue as "hello world".
Assign the result from the method to a variable named result.
var result = RunWorkflow("BusinessProcess\\CodedResetAssetValue.cs", new Dictionary<string, object>()
{"assetName", "MyAsset"},
{"assetValue", "hello world"}
- Use an if-else statement to check if
assetValueWasChangedis true.- If
assetValueWasChangedis true, log a message that indicates the asset was reset and include the previous value it had. - If it is false, log a message specifying that no reset was required on the asset because it had the expected value.
- If
