- Release Notes
- Getting Started
- Setup and Configuration
- Automation Projects
- Dependencies
- Types of Workflows
- File Comparison
- Automation Best Practices
- Source Control Integration
- Debugging
- The Diagnostic Tool
- Workflow Analyzer
- About Workflow Analyzer
- ST-DBP-023 - Empty Workflow
- Variables
- Arguments
- Imported Namespaces
- Control Flow
- Object Repository
- Logging
- Studio testing
- Extensions
- Troubleshooting
Activity Project Settings represent a set of changes that can be configured at the project level and applied to all activities part of project dependencies.
To configure activity properties at project level click the
icon in the Project panel. The Project Settings window opens:
The Activity Settings list shows tabs for each installed activity package, and some bundled dependencies like Computer Vision part of UIAutomation.
These settings may be configured for two scenarios: Production and Debug. In this way, for the same activities in the project, specific settings are applied in production, when the project is run, while a different set of settings are enforced during debugging.
BrowserType property with the IE default browser for opening the URL. If in Activity Project Settings, the same property is set to open URLs in Firefox, then this setting overwrites defaults and applies to all activities with
this property used in the project.
BrowserType property set to Chrome in its Properties panel, then the value set in the panel overwrites any other value configured in the Activity Project Settings window.
A set of actions are available in the Bulk Action drop-down menu for performing changes to multiple settings:
- Reset all
- Reset production settings
- Reset debug settings
- Copy debug settings to production
- Copy production settings to debug.
Please bear in mind that even though activity properties are changed from the Property Settings window and new values are applied throughout the project, the default values in the Properties panel are not visibly updated. The change is applied, but not visible in the Properties panel.
The configured activity settings are saved in the project location, and are visible in the Project panel, under the .settings folder.
To save your Activity Project Settings configuration and apply it to other future automation projects use the Save as Template functionality in Studio.
Check out the Project Settings page to read more about these properties.
