robot
Robot admin guide
Last updated Apr 23, 2026
Using EntraID users with multifactor authentication (MFA) for unattended robots
Multifactor authentication (MFA) adds an extra layer of security by requiring users to verify their identity using two or more factors, such as:
  • Something you know: a password
  • Something you have: a mobile device or smart card
  • Something you are: a fingerprint or face scan
MFA helps protect against unauthorized access, even if a password is compromised. However, it introduces additional complexity when setting up unattended automations.
Passwords count as a single authentication factor. Because MFA requires at least two factors, Robots cannot create user sessions using password credentials alone.
To enable MFA users to authenticate, you can use smart card credentials instead.
Important:
Smart card authentication requires Login to Console to be set to True. It does not work with RDP sessions, which means it is not compatible with High-Density Robot environments. For more details, see SmartCard Authentication.
Step 1: Create virtual smart cards
Virtual smart cards are easier to deploy and manage across multiple machines.
You must create virtual smart cards on all virtual machines (VMs) where robots run. Do this for each Entra ID user that executes automations.
A virtual smart card functions as a physical one, but instead of using a physical container, it relies on the machine Trusted Platform Module (TPM) chip to securely store cryptographic keys.
Step 2: Configure Entra certificate-based authentication
After creating the virtual smart cards, configure Entra certificate-based authentication to allow Entra ID users to authenticate using certificates.
The certificates used for authentication must be configured as multi-factor to meet MFA requirements.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
