robot
Robot Admin Guide
Last updated Feb 6, 2026
Robot Executor
The robot executor (UiPath.Executor.exe) is the robot component directly responsible for executing a process. When a job is started, the robot service launches a robot executor instance.
The Executor is always aware of DPI settings per-monitor. As a result, workflows can be executed at any DPI, regardless of the configuration on the machine they were created on. For apps that are DPI-unaware, or intentionally marked as unaware, you can choose to disable DPI.
Executor types
Based on the automation project, the robot service launches the type of executor intended to run the automation.
There is a type of executor for each of the automation project type available:
Project Type
Architecture
Supported platforms
Framework
Windows - Legacy
32-bit
Windows (32-bit and 64-bit)
.NET Framework 4.6.1
Windows
64-bit
Windows (64-bit)
.NET 6 with Windows support
Cross-platform
64-bit
Windows, Linux, and macOS (64-bit)
.NET 6 with cross-platform support
  • Executor types
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
