- Getting Started with Test Suite
- Studio
- Test Suite - Studio
- Overview
- Testing activities and coded automation APIs
- Orchestrator
- Testing robots
- Test Manager
Test Suite User Guide
Tenant level settings in Test Manager allow you to apply various settings across all projects within a given tenant. To access Tenant level toggles, go to Test Manager, select Settings in the header, and access the General tab.
Check the following settings you can apply for all projects inside a tenant:
The Allow legacy execution context setting allows you to enable the execution of test sets, which have no Orchestrator folder context assigned. This was the default behavior before this setting became available. Test sets without folder context are executed in a random folder on Orchestrator.
Turn off this setting to enforce a folder selection for each automated execution of test sets. This setting ensures backward compatibility for test sets created before this setting became available. We recommend to have this setting disabled for future test execution.
Visit Configuring test sets for specific execution folders for more information about executing test cases from a certain execution folder.
