test-suite
- Getting Started with Test Suite
- Studio
- Orchestrator
- Testing robots
- Test Manager
Direct connection to SAP instance
Test Suite User Guide
Last updated Dec 18, 2024
To create an integration between your Test Manager project and your SAP system to collect data periodically, using a connection to your SAP system:
This task demonstrates how to integrate the SAP NetWeaver RFC SDK
with your SAP system, so you can use the heatmap in Test Manager deployed with Automation Suite.
- Test Manager installed with Automation Suite.
- SAP Netweaver RFC SDK 7.50
- Test Manager migrator shell script. Make sure you meet the
following environment requirements:
kubectl
configured with a connection to the Automation suite cluster.jq
(install it using the following command:yum install jq
)argocd
CLI (Installation - Argo CD - Declarative GitOps for Kubernetes)rclone
(Install Rclone)
After you move the SAP libraries to your Automation Suite storage locations, perform the following validation steps:
- Check if you can access Test Manager inside Automation Suite.
- You can create a custom connection with your SAP system in a Test Manager project.
