test-suite
OUT OF SUPPORT
Test Suite User Guide
Last updated May 14, 2025
Users and Groups
Manage the list of users and roles who have access to Test Manager.
Conditions
To receive emails about user access authorizations, you need to configure email notifications.
User Roles and Privileges
Test Manager supports two roles: Administrator and User. You can assign one of these roles to your users. The following table lists the privileges of each role.
Privileges
Administrator
User
Read, update and delete objects within any project
available
available
Create projects
available
not available
Activate/deactivate users
available
not available
Access to maintenance tasks
available
not available
Access to application settings
available
not available
Access project settings and the administration section
available
not available
User Access Management
As an administrator, you can manage users by authorizing, rejecting, disabling, and editing access to Test Manager.
If you are an Orchestrator admin and you log in for the first time in Test Manager, you inherit the administrator.
To create a Test Manager user, you need to add a local user in Orchestrator. The user will log in to Test Manager, and be requested to change the password.
Manage User Access
To manage user access, open Test Manager, click the vertical ellipsis at the upper-right corner of the page and select Users and Groups.
The following table lists the actions that you can take to manage your users.
Action
Procedure
Authorize/Reject
Authorize access to users that have requested it through the login page. Authorizing a user request sets their status as Active. Correspondingly, rejecting a user request sets their status as Disabled.
To keep yourself up-to-date with user access requests and authorizations, you need to configure Email Notifications.
  1. In the Users and Groups page, go to Pending Authorization.
  2. Select a user and click the docs image vertical ellipsis button to open the dropdown menu.
  3. Select Authorize or Disable.
Disable
Disable user access to Test Manager. The user status is set to Disabled and its entry is moved to the Disabled tab.
  1. In the Users and Groups page, go to one of the user tabs (All, Users, Administrators).
  3. Click Disable.
Update
Update user roles to Admin or User.
  2. Click a username.
  3. Click the Admin Role toggle to switch it on or off.
  4. Click Save.
Troubleshooting Access Management
Users that have been disabled receive the following message:
To solve this issue, the user can request access, followed by approval by the Test Manager administrator.
  • Users and Groups
  • Conditions
  • User Roles and Privileges
  • User Access Management
  • Manage User Access
  • Troubleshooting Access Management
