2022.4
Automation Suite API guide
  • Getting started
    • About this guide
    • Available resources
    • API endpoint URL structure
    • Enumeration List
  • Authentication
  • Scopes and permissions
  • Platform Management APIs
Get Specific Group
Returns information about a group, based on the organization and group ID.
API Endpoint​
GET https://{yourDomain}/{organizationName}/identity_/api/Group/{partitionGlobalId}/{groupId}
Scopes​
Requires the following scopes:
  • PM.Group
  • PM.Group.Read
Request Headers​
Note:
To obtain the {access_token}, make sure to authenticate through one of the methods described here.
Path Parameters​
Path paramData typeDescription
partitionGlobalId
(required)
StringThe ID of the organization containing the desired group.
groupID
(required)
StringThe ID of the group you want to retrieve.
Responses​
200 OK​
The specified group information is returned.
Example Request​
Let's say you gathered all the information needed to build the API call.
  • Your {baseURL} is: https://{yourDomain}/{organizationName}/identity_
  • Your {access_token} is: 1234 (for length considerations).
  • The {partitionGlobalId} is: 3fa85f64-5717-4562-b3fc-2c963f66afa6
  • The {groupID} is: 2512
The call should resemble the following example (cURL):
curl --location --request GET 'https://{yourDomain}/{organizationName}/identity_/api/Group/3fa85f64-5717-4562-b3fc-2c963f66afa6/2512' \
Here's the response body for a successful call:
    "id": "2512",
    "name": "Automation Developers",
    "displayName": "Automation Developers",
    "type": 0,
    "creationTime": "2021-10-19T14:25:01.6574988",
    "lastModificationTime": "2021-10-19T14:25:01.6574988",
    "members": [
            "objectType": "DirectoryUser",
            "firstName": "Albus",
            "lastName": "D",
            "jobTitle": "master",
            "companyName": "Hogwarts",
            "city": "London",
            "department": "magic",
            "displayName": "Albus D",
            "source": "local",
            "identifier": "1787ef38-5933-4f2c-a67a-9c22cdb8e6a2",
            "name": "albus",
            "email": "[email protected]"
    "id": "2512",
    "type": 0,
    "members": [
            "lastName": "D",
            "city": "London",
            "source": "local",
            "name": "albus",
  • API Endpoint​
  • Scopes​
  • Request Headers​
  • Path Parameters​
  • Responses​
  • 200 OK​
  • Example Request​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
