Last updated Nov 13, 2025
Exploring summarized telemetry
Viewing summarized telemetry XML file
To view the XML file generated with the support bundle that summarizes basic usage telemetry you can open the XML file using SQL Sever Management Studio or in any XML viewer you are familiar.
  • Viewing summarized telemetry XML file
