- Overview
- UI Automation
- Applications and technologies automated with UI Automation
- Project compatibility
- UI-ANA-016 - Pull Open Browser URL
- UI-ANA-017 - ContinueOnError True
- UI-ANA-018 - List OCR/Image Activities
- UI-DBP-006 - Container Usage
- UI-DBP-013 - Excel Automation Misuse
- UI-DBP-030 - Forbidden Variables Usage In Selectors
- UI-DBP-031 - Activity verification
- UI-PRR-001 - Simulate Click
- UI-PRR-002 - Simulate Type
- UI-PRR-003 - Open Application Misuse
- UI-PRR-004 - Hardcoded Delays
- UI-REL-001 - Large Idx in Selectors
- UI-SEC-004 - Selector Email Data
- UI-SEC-010 - App/Url Restrictions
- UI-USG-011 - Non Allowed Attributes
- UX-SEC-010 - App/Url Restrictions
- UX-DBP-029 - Insecure Password Use
- UI-PST-001 - Audit Log Level in Project Settings
- UiPath Browser Migration Tool
- Clipping region
- Computer Vision Recorder
- Activities index
- Activate
- Anchor Base
- Attach Browser
- Attach Window
- Block User Input
- Callout
- Check
- Click
- Click Image
- Click Image Trigger
- Click OCR Text
- Click Text
- Click Trigger
- Close Application
- Close Tab
- Close Window
- Context Aware Anchor
- Copy Selected Text
- Element Exists
- Element Scope
- Export UI Tree
- Extract Structured Data
- Find Children
- Find Element
- Find Image
- Find Image Matches
- Find OCR Text Position
- Find Relative Element
- Find Text Position
- Get Active Window
- Get Ancestor
- Get Attribute
- Get Event Info
- Get From Clipboard
- Get Full Text
- Get OCR Text
- Get Password
- Get Position
- Get Source Element
- Get Text
- Get Visible Text
- Go Back
- Go Forward
- Go Home
- Google Cloud Vision OCR
- Hide Window
- Highlight
- Hotkey Trigger
- Hover
- Hover Image
- Hover OCR Text
- Hover Text
- Image Exists
- Indicate On Screen
- Inject .NET Code
- Inject Js Script
- Invoke ActiveX Method
- Key Press Trigger
- Load Image
- Maximize Window
- Microsoft Azure Computer Vision OCR
- Microsoft OCR
- Minimize Window
- Monitor Events
- Mouse Trigger
- Move Window
- Navigate To
- OCR Text Exists
- On Element Appear
- On Element Vanish
- On Image Appear
- On Image Vanish
- Open Application
- Open Browser
- Refresh Browser
- Replay User Event
- Restore Window
- Save Image
- Select Item
- Select Multiple Items
- Send Hotkey
- Set Clipping Region
- Set Focus
- Set Text
- Set To Clipboard
- Set Web Attribute
- Show Window
- Start Process
- System Trigger
- Take Screenshot
- Tesseract OCR
- Text Exists
- Tooltip
- Type Into
- Type Secure Text
- Use Foreground
- Wait Attribute
- Wait Element Vanish
- Wait Image Vanish
- Application Event Trigger
- Check/Uncheck
- Check App State
- Check Element
- Click
- Click Event Trigger
- Drag and Drop
- Extract Table Data
- For Each UI Element
- Get Browser Data
- Get Clipboard
- Get Text
- Get URL
- Go to URL
- Highlight
- Hover
- Inject Js Script
- Keyboard Shortcuts
- Keypress Event Trigger
- Mouse Scroll
- Navigate Browser
- Select Item
- Set Browser Data
- Set Clipboard
- Set Runtime Browser
- Set Text
- Take Screenshot
- Type Into
- Use Application/Browser
- Window Operation
- Perform browser search and retrieve results using UI Automation APIs
- Web Browsing
- Find Images
- Click Images
- Trigger and Monitor Events
- Create and Override Files
- HTML Pages: Extract and Manipulate Information
- Window Manipulation
- Automated List Selection
- Find and Manipulate Window Elements
- Manage Text Automation
- Load and Process Images
- Manage Mouse Activated Actions
- Automate Application Runtime
- Automated Run of a Local Application
- Browser Navigation
- Web Automation
- Trigger Scope Example
- Enable UI Automation support in DevExpress
- Mobile Automation
- Release notes
- About the mobile device automation architecture
- Get Log Types
- Get Logs
- Get Page Source
- Get Device Orientation
- Get Session Identifier
- Install App
- Manage Current App
- Manage Other App
- Open DeepLink
- Open URL
- Mobile Device Connection
- Directional Swipe
- Draw Pattern
- Positional Swipe
- Press Hardware Button
- Set Device Orientation
- Take Screenshot
- Take Screenshot Part
- Element Exists
- Execute Command
- Get Attribute
- Get Selected Item
- Get Text
- Set Selected Item
- Set Text
- Swipe
- Tap
- Type Text
- Terminal
UI Automation Activities
If you run into problems, consider the following troubleshooting scenarios:
The topics below describe the problems, and their corresponding remedies, for Mobile Device Automation.
Workflow and activities generating errors
Description: The workflow in Studio throws unexpected errors, and the activity packages don't display the versions installed.
Cause: Inside your project, the major version of the UI.Automation activity package doesn't match the major version of the Mobile.Automation activity package. For example, the major version of the UI.Automation package installed is 22.10.x, and the major version of the Mobile.Automation package installed is 22.4.x.
Remedy: Make sure that the major versions of the UI.Automation and Mobile.Automation activity packages, installed in your project, match. For example, pair UI.Automation.Activities version 22.10.x only with Mobile.Automation.Activities version 22.10.x.
No route found for wd/hub/ session
Condition: When using Appium 2.0.
/wd/hub/session
--base-path /wd/hub
Vendor prefix needed for all non-standard capabilities
Description: All non-standard capabilities should have a vendor prefix.
appium:
prefix for all capabilities, as follows:
- In the command prompt or terminal, instead of
--default-capabilities "{\"systemPort\": 8201}"
, input--default-capabilities "{\"appium:systemPort\": 8201}"
. - In the Add a device tab from Mobile Device Manager, manually add the
appium:
prefix before the name of any additional desired capability.
automationName can't be blank
automationName
capability can't be blank.
appium:
as a prefix. For example, appium:automationName
Can't find the installed driver
Description: Could not find the installed driver to support given caps.
Appium 2.0 doesn't automatically install the required drivers. You have to download them separately.
Remedy: Install the required driver for your platform.
- For Android devices, install the
uiautomator2
driver, using theappium driver install uiautomator2
command. - For iOS devices, install the
xcuitest
driver, using theappium driver install xcuitest
command.
The following topics describe the problems for Android devices, and their corresponding remedies.
Connection failure due to
InvalidArgumentException
for capabilities
coming from a discrepancy in the
expected format of a capability. The issue arises when a capability is entered as a
String, while Appium expects a Boolean value. An indicative error message
includes:Failed to create session.
A new session could not be created.
Details: io.appium.uiautomator2.common.exceptions.InvalidArgumentException:
Invalid '<capability name>' setting value type.
Got java.lang.String. Expected: java.lang.Boolean
Remedy: Uninstall the following apps from the local device:
io.appium.uiautomator2.server
io.appium.uiautomator2.server.test
Activity failure due to a WebDriverException
WebDriverException
. This error typically
displays as Parameters were incorrect. We wanted {\"required\":[\"text\"]}
and you sent [\"value\"]", "FaultCode":"WebDriverException"}
Remedy: Uninstall your current version of UiAutomator 2. Then install a newer version, using the following commands in the given order:
appium driver uninstall uiautomator2
appium driver install [email protected]
, where2.29.0
is the version that you want to install. You can replace this with any available version.
Appium installation fails due to proxy
npm install -g appium
(for Appium
1.x), or npm install -g appium@next
(for Appium 2.0)
command fails, because you're running behind a proxy. The error throws the following
message:
npm ERR! network This is a problem related to network connectivity.
npm ERR! network In most cases you are behind a proxy or have bad network settings.
npm ERR! network npm ERR! network If you are behind a proxy, please make sure that the npm ERR! network 'proxy' config is set properly.
See: 'npm help config'
Remedy: Configure npm (Node Package Manager) to use your proxy. Follow the steps below:
Fetch your proxy server address, and your port number:
- Go to Internet Options.
- Select the Connections tab.
Select LAN settings, and copy the content inside the Address, and Port fields.
Return to the Node.js command prompt, and run a command that follows the format below:
- For HTTP proxies:
npm config set http://your_proxy_address:your_port_number
. - For HTTPS proxies:
npm config set https://your_proxy_address:your_port_number
- For HTTP proxies:
- Run the
(for Appium 1.x), ornpm install -g appium@next
(for Appium 2.0) command again.
Could not access the provided web context
Description: Could not access the provided web context. Ensure that the Android WebView is debuggable. Visit Remote debugging WebViews for more information about accessing web contexts.
Remedies:
- Use the WebView as Native selectors on the web contexts that aren't recognized.
- If the selectors work on web applications, but not on a native application, then the application doesn’t enable debugging webviews. In this case, see Get started with remote debugging Android WebViews, and Remote debugging WebViews.
Device not authorized
Description: Device not authorized.
Remedy: Take the following steps:
- Use the
adb devices
command to check the existent devices. - Revoke Debugging on phone.
- Restart the ADB server, by using the following commands, in this order:
adb kill-server
, and thenadb start-server
. - Reconnect the device, and confirm that you agree to the connection on that device.
Browser Automation while starting from the launch screen
Description: The Android device launches a browser automation instead of the given app, therefore causing errors.
Remedy: Start with a web browser instead.
Android app doesn't launch
Description: the Android app that you created doesn't launch in Mobile Device Manager.
Remedy:
- Hover over the application and click Edit.
- Add information about the app inside the App package and App activity fields.
The topics below describe the problems, and their corresponding remedies, for iOS devices.
Cannot click WebView elements on iOS 13
Description: When you click a WebView element the selector doesn't work, and you can't automate the element.
Remedy: Use simulators with the latest version of iOS and Appium 2.
iOS physical device fails to start
Description: iOS physical device fails to start.
- Make sure that your device is trusting the certificate. On your device, go to Settings > General > Profiles & Device Management, tap on the email entry (e.g. Apple Development: [email protected]), and then trust the certificate. If the device is using your corporate account, this would not be needed.
- If you get an error that port 8100 is not accessible, close Appium (
ctrl + c
) and then restart it. - If you get a different error, consider looking through Appium XCUITest Driver Real Device.
iOS 16.0 device fails to start
Description: iOS 16.0 device fails to start or connect.
Remedy: Install and use Appium 2.0, instead of Appium 1. Check the Local iOS device prerequisites section for more information on installing and managing Appium 2.0.
iOS 12.4.5 malfunctions
Description: iOS 12.4.5 doesn't work as expected while paired with Appium 1.22.3.
Cause: This is caused by an issue with Appium.
Remedy: Choose one of the options below:
- Use a lower version of Appium, such as 1.17.0.
- Upgrade the device to versions equal to, or higher than iOS 14.
- Troubleshooting scenarios
- Mobile device automation
- Workflow and activities generating errors
- No route found for wd/hub/ session
- Vendor prefix needed for all non-standard capabilities
- automationName can't be blank
- Can't find the installed driver
- Android
- Connection failure due to
for capabilities - Activity failure due to a
WebDriverException
- Appium installation fails due to proxy
- Could not access the provided web context
- Device not authorized
- Browser Automation while starting from the launch screen
- Android app doesn't launch
- iOS
- Cannot click WebView elements on iOS 13
- iOS physical device fails to start
- iOS 16.0 device fails to start
- iOS 12.4.5 malfunctions
