test-suite
- Getting Started
- Studio
- Orchestrator
- Testing robots
- Test Manager
Configuring system under test
OUT OF SUPPORT
Test Suite User Guide
Last updated May 14, 2025
To perform test automation in your System Under Test (SUT), you need to set up the right user and assign the correct authorizations.
To configure your system under test, follow these procedures:
You need to manually create the user ECATT_ET_USR in the SUT.
- Create ECATT_ET_USR in transaction SU01.
- Ensure that the user type is System.
- The password for both users (in SAP Solution Manager and SUT) should be the same to ensure seamless integration.
Studio and Robots require SAP WinGUI scripting to be enabled on the local machine as well as on the server side. Before you can create your first automation projects for SAP, you need to go over the configuration steps.
