document-understanding
Document Understanding user guide
Last updated Apr 15, 2026
First run experience
Use the following steps to access Document UnderstandingTM in Automation Suite:
  1. Activate the license
  2. Enable AI Center on the tenant
  3. Create a project on AI Center
  4. Upload the model base images
  5. Create a data labeling session
  6. Launch the data labeling session
Sign in to Automation Suite, then go to Admin > Licenses and input your license key. More information on how to access Automation Suite can be found here.
Upon successful activation, under Consumables, AI Units quantity should not be 0. A specified number of pages are shown for Document Understanding after selecting the Generate new button.
Go to Admin > Tenants, select the three dot menu and select AI Center as a provision service under Tenant Setting.
Note:
If Document Understanding is enabled on your tenant without the activation of Document Understanding modern projects, the Document Understanding application (accessible from the list on the left side) will not work. To access Document Understanding AI Center-based projects, use the AI Center application instead. However, if Document Understanding modern projects are activated, you can access Document Understanding through the applications list on the left side. Screenshot of the Create a new tenant interface
  1. To create a project on AI Center, select AI Center on the left rail, and then select Create Project from the top bar.
  2. Enter a project name and select Create.
Upload the Document Understanding ML packages
Note:
This step is required only for offline installation. For online installation, skip this step as all the models should already be under ML Packages > Out of the box Packages > UiPath Document Understanding.
Upload the Document UnderstandingTM ML Packages to AI Center. You need to upload only the models you want to use.
Detailed instructions can be found here.
If you are using Form Extractor, Intelligent Form Extractor, and Intelligent Keyword Classifier, you can directly access the model without uploading it to AI Center. Detailed instructions can be found here.
Create a Data Labeling session
Create a data labeling session to use Data Manager to label your dataset and retrain the base model.
  1. Go to Data Labeling > UiPath Document Understanding.
    Screenshot of the Create new Data Labeling App interface.
  2. Name the data labeling session, enable the Create new dataset slider.
  3. Name the dataset and then select Create.
    Screenshot of the Create new data labeling session interface.
This may take a few minutes to deploy. Please refresh the page if the status does not change.
Launch the Data Labeling session
Select the newly created data labeling session from the list to launch it.
Screenshot of the Document Manager open page.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
