Automation Suite API guide
- Getting started
- Authentication
- Scopes and permissions
- Platform Management APIs
- Get Settings
- Update Settings
Use this endpoint to retrieve the list of key-value pairs for email and authentication settings.
API Endpoint
GET https://{yourDomain}/{organizationName}/identity_/api/Setting
Scopes
Requires the following scopes:
- PM.Setting
- PM.Setting.Read
Request Headers
Note:
To obtain the {access_token}, make sure to authenticate through one of the methods described here.
Query Parameters
| Query param | Data type | Description |
key(optional) | String | Enter the name of the setting you want to retrieve. For example, to retrieve the SMTP Domain setting, enter key=Email.Smtp.Domain. |
partitionGlobalId(optional) | String | The ID of the organization you want to retrieve the settings for. |
userId(optional) | String | The ID of the user you want to retrieve the settings for. |
Responses
200 OK
Returns the queried robot accounts.
Example Request
Let's say you gathered all the information needed to build the API call.
- Your
{baseURL}is: https://{yourDomain}/{organizationName}/identity_ - Your
{access_token}is:1234(for length considerations). - The
{partitionGlobalId}is:3fa85f64-5717-4562-b3fc-2c963f66afa6 - You want to retrieve the global email settings, so you log in as the host admin. In this case, you don't provide a
userID.
The call should resemble the following example (cURL):
curl --location --request GET 'https://{yourDomain}/{organizationName}/identity_/api/Setting?partitionGlobalId=3fa85f64-5717-4562-b3fc-2c963f66afa6&key=Email.Smtp.Domain&key=Email.Smtp.EnableSsl&key=Email.Smtp.FromDisplayName&key=Email.Smtp.FromEmail&key=Email.Smtp.Host&key=Email.Smtp.Password&key=Email.Smtp.Port&key=Email.Smtp.UseDefaultCredentials&key=Email.Smtp.UserName' \
Here's the response body for a successful call:
"id": 6,
"key": "Email.Smtp.FromEmail",
"value": "[email protected]",
"partitionGlobalId": "3fa85f64-5717-4562-b3fc-2c963f66afa6",
"userId": null
"id": 7,
"key": "Email.Smtp.FromDisplayName",
"value": "Hogwarts server - 21.10 - Clean",
"userId": null
"id": 15,
"key": "Email.Smtp.Domain",
"value": "",
"userId": null
"id": 16,
"key": "Email.Smtp.EnableSsl",
"value": "true",
"userId": null
"id": 17,
"key": "Email.Smtp.Port",
"value": "587",
"userId": null
"id": 18,
"key": "Email.Smtp.UseDefaultCredentials",
"value": "false",
"userId": null
"id": 19,
"key": "Email.Smtp.UserName",
"userId": null
"id": 20,
"key": "Email.Smtp.Host",
"value": "smtp.gmail.com",
"userId": null
"id": 21,
"key": "Email.Smtp.Password",
"value": "protego-spell",
"userId": null
"id": 6,
"userId": null
"id": 7,
"userId": null
"id": 15,
"value": "",
"userId": null
"id": 16,
"value": "true",
"userId": null
"id": 17,
"value": "587",
"userId": null
"id": 18,
"value": "false",
"userId": null
"id": 19,
"userId": null
"id": 20,
"userId": null
"id": 21,
"userId": null
