- Overview
- UI Automation
- Applications and technologies automated with UI Automation
- Project compatibility
- UI-ANA-016 - Pull Open Browser URL
- UI-ANA-017 - ContinueOnError True
- UI-ANA-018 - List OCR/Image Activities
- UI-DBP-006 - Container Usage
- UI-DBP-013 - Excel Automation Misuse
- UI-DBP-030 - Forbidden Variables Usage In Selectors
- UI-DBP-031 - Activity verification
- UI-PRR-001 - Simulate Click
- UI-PRR-002 - Simulate Type
- UI-PRR-003 - Open Application Misuse
- UI-PRR-004 - Hardcoded Delays
- UI-REL-001 - Large Idx in Selectors
- UI-SEC-004 - Selector Email Data
- UI-SEC-010 - App/Url Restrictions
- UI-USG-011 - Non Allowed Attributes
- UX-SEC-010 - App/Url Restrictions
- UX-DBP-029 - Insecure Password Use
- UI-PST-001 - Audit Log Level in Project Settings
- UiPath Browser Migration Tool
- Clipping region
- Computer Vision Recorder
- Activities index
- Activate
- Anchor Base
- Attach Browser
- Attach Window
- Block User Input
- Callout
- Check
- Click
- Click Image
- Click Image Trigger
- Click OCR Text
- Click Text
- Click Trigger
- Close Application
- Close Tab
- Close Window
- Context Aware Anchor
- Copy Selected Text
- Element Exists
- Element Scope
- Export UI Tree
- Extract Structured Data
- Find Children
- Find Element
- Find Image
- Find Image Matches
- Find OCR Text Position
- Find Relative Element
- Find Text Position
- Get Active Window
- Get Ancestor
- Get Attribute
- Get Event Info
- Get From Clipboard
- Get Full Text
- Get OCR Text
- Get Password
- Get Position
- Get Source Element
- Get Text
- Get Visible Text
- Go Back
- Go Forward
- Go Home
- Google Cloud Vision OCR
- Hide Window
- Highlight
- Hotkey Trigger
- Hover
- Hover Image
- Hover OCR Text
- Hover Text
- Image Exists
- Indicate On Screen
- Inject .NET Code
- Inject Js Script
- Invoke ActiveX Method
- Key Press Trigger
- Load Image
- Maximize Window
- Microsoft Azure Computer Vision OCR
- Microsoft OCR
- Minimize Window
- Monitor Events
- Mouse Trigger
- Move Window
- Navigate To
- OCR Text Exists
- On Element Appear
- On Element Vanish
- On Image Appear
- On Image Vanish
- Open Application
- Open Browser
- Refresh Browser
- Replay User Event
- Restore Window
- Save Image
- Select Item
- Select Multiple Items
- Send Hotkey
- Set Clipping Region
- Set Focus
- Set Text
- Set To Clipboard
- Set Web Attribute
- Show Window
- Start Process
- System Trigger
- Take Screenshot
- Tesseract OCR
- Text Exists
- Tooltip
- Type Into
- Type Secure Text
- Use Foreground
- Wait Attribute
- Wait Element Vanish
- Wait Image Vanish
- Application Event Trigger
- Block User Input
- Check/Uncheck
- Check App State
- Check Element
- Click
- Click Event Trigger
- Drag and Drop
- Extract Table Data
- For Each UI Element
- Get Browser Data
- Get Clipboard
- Get Text
- Get URL
- Go to URL
- Highlight
- Hover
- Inject Js Script
- Keyboard Shortcuts
- Keypress Event Trigger
- Mouse Scroll
- Navigate Browser
- Select Item
- Set Browser Data
- Set Clipboard
- Set Runtime Browser
- Set Focus
- Set Text
- Take Screenshot
- Type Into
- Unblock User Input
- Use Application/Browser
- Window Operation
- Perform browser search and retrieve results using UI Automation APIs
- Web Browsing
- Find Images
- Click Images
- Trigger and Monitor Events
- Create and Override Files
- HTML Pages: Extract and Manipulate Information
- Window Manipulation
- Automated List Selection
- Find and Manipulate Window Elements
- Manage Text Automation
- Load and Process Images
- Manage Mouse Activated Actions
- Automate Application Runtime
- Automated Run of a Local Application
- Browser Navigation
- Web Automation
- Trigger Scope Example
- Enable UI Automation support in DevExpress
- Mobile Automation
- Release notes
- About the mobile device automation architecture
- Get Log Types
- Get Logs
- Get Page Source
- Get Device Orientation
- Get Session Identifier
- Install App
- Manage Current App
- Manage Other App
- Open DeepLink
- Open URL
- Mobile Device Connection
- Directional Swipe
- Draw Pattern
- Positional Swipe
- Press Hardware Button
- Set Device Orientation
- Take Screenshot
- Take Screenshot Part
- Element Exists
- Execute Command
- Get Attribute
- Get Selected Item
- Get Text
- Set Selected Item
- Set Text
- Swipe
- Tap
- Type Text
- Terminal
UI Automation Activities
To build automations for Reach Native apps, you can use the React Native Demo App for iOS to learn how to make specific components ready to automate.
- UiPath.MobileAutomation.Activities
Alternatively, you can use the Mobile Testing Project default template, as this will install the activity package for you.
- Device farm or Physical Mobile Device (see Managing Devices).
- Appium endpoint.
For this example, the TouchableOpacity component is being used to automate touch-based input. You can set other views as accessible as the behavior will be similar with the TouchableOpacity component.
In this example, we use the React Native Demo App for iOS to configure specific properties to make components automatable.
Accessibility properties
indicates the view as an accessibility element. Accessibility set to true makes an element automatable. All touchable components
are accessible by default (see React Native Accessibility).
<View accessible={true}>
<Text>text one</Text>
<Text>text two</Text>
</View>
</View>
Property |
Type |
Description |
bool |
string |
Makes the component automatable despite its parent accessibility status (true or false).
Mobile automation sample
Use the following mobile automation sample as a starting point to building the automation according to your requirements. Alternatively, you can use Mobile Device Manager to record steps and then import them to Studio.
import React from 'react';
import type { Node } from 'react';
import {
SafeAreaView,
ScrollView,
StatusBar,
StyleSheet,
Text,
Alert,
useColorScheme,
View,
TouchableOpacity,
Button
} from 'react-native';
import {
Colors,
DebugInstructions,
Header,
LearnMoreLinks,
ReloadInstructions,
} from 'react-native/Libraries/NewAppScreen';
import symbolicateStackTrace from 'react-native/Libraries/Core/Devtools/symbolicateStackTrace';
const App: () => Node = () => {
const isDarkMode = useColorScheme() === 'dark';
const backgroundStyle = {
backgroundColor: isDarkMode ? Colors.darker : Colors.lighter,
const click = () => {
Alert.alert("click!! ")
return (
<View style={styles.container}>
<TouchableOpacity style={styles.top} accessible={true}>
<View>
<Text accessible={true} style={[styles.text1, backgroundColor = "lightblue"]}>Touchable opacity(TO) accessible = true</Text>
<Text accessible={true} style={[styles.text1, backgroundColor = "lightblue"]}>Accessible true on TO groups all elements within TO</Text>
</View>
<View >
<Text accessible={true} style={styles.text2} onPress={click}>Accessible true text in view</Text>
</View>
<Button accessible={true} color="white" title='Button accessible true' onPress={click}></Button>
</TouchableOpacity>
<TouchableOpacity style={styles.middle} accessible={true}>
<View>
<Text style={styles.text1}>Touchable opacity </Text>
<Text style={styles.text1}>accessible = true</Text>
<Text style={styles.text1}>Despite accessible true on TO, testID ungroups all elements within and makes them automatable</Text>
</View>
<Text testID='text1' style={styles.text2} onPress={click}>Text with testID</Text>
<Text style={styles.text2} onPress={click}>Text without testID</Text>
<View testID='view1'>
<Text style={styles.text2} onPress={click}>Text in a view with testID</Text>
<Text style={styles.text2} onPress={click}>Second text in a view with testID</Text>
</View>
<Button testID='button1' accessible={true} title='Button with testID' onPress={click}></Button>
</TouchableOpacity>
<TouchableOpacity style={styles.bottom} accessible={false}>
<View>
<Text style={styles.text1}>accessible = false</Text>
<Text style={styles.text1}>Setting accessible false ungroups all elements contained by TO</Text>
</View>
<View >
<Text style={styles.text2} onPress={click}>Text without accessible mentioned</Text>
</View>
<Button title='Button without accessible mentioned' onPress={click}></Button>
</TouchableOpacity>
</View>
const styles = StyleSheet.create({
container: {
flex: 1,
justifyContent: "space-between",
backgroundColor: "#fff",
padding: 20,
margin: 20,
top: {
flex: 0.2,
backgroundColor: "grey",
borderWidth: 5,
borderRadius: 20,
justifyContent: "center",
alignContent: "center"
middle: {
flex: 0.4,
backgroundColor: "beige",
borderWidth: 5,
bottom: {
flex: 0.3,
backgroundColor: "pink",
borderWidth: 5,
borderRadius: 20,
text1: {
alignContent: "center",
textAlign: "center"
text2: {
margin: 10,
backgroundColor: "lightblue",
padding: 1,
borderWidth: 2,
button: {
color: "white",
export default App;
import {
SafeAreaView,
ScrollView,
StatusBar,
StyleSheet,
Text,
Alert,
useColorScheme,
View,
TouchableOpacity,
Button
import {
Colors,
DebugInstructions,
Header,
LearnMoreLinks,
ReloadInstructions,
return (
<View>
</View>
<View >
</View>
</TouchableOpacity>
<View>
</View>
</View>
</TouchableOpacity>
<View>
</View>
<View >
</View>
</TouchableOpacity>
</View>
container: {
flex: 1,
padding: 20,
margin: 20,
top: {
flex: 0.2,
borderWidth: 5,
borderRadius: 20,
middle: {
flex: 0.4,
borderWidth: 5,
bottom: {
flex: 0.3,
borderWidth: 5,
borderRadius: 20,
text1: {
textAlign: "center"
text2: {
margin: 10,
padding: 1,
borderWidth: 2,
button: {
color: "white",
export default App;
