test-suite
Test Suite User Guide
Last updated May 14, 2025
User and Group Access Management
Manage access to Test Manager by assigning users and groups to your projects.
Conditions
  • The Administrator is set by default as Project owner on all projects. This role is independent of any role assignment.
  • Access to Test Manager privileges is granted only by the Administrators or the Project owner, by assigning users and roles to the project.
  • You can transfer project ownership to another user only if you are an Administrator or a Project owner.
  • Users that are signed in cannot be removed until they sign out.
User roles and privileges
Test Manager supports multiple roles: Project owner, Test Manager,Manual Tester,Test Designer,Test Executor,Read Only. The following table lists the privileges of each role.
Privileges
Admin/Project owner
Test Manager
Test Designer
Test Executor
Manual Tester
Read Only
available
not available
not available
not available
not available
not available
Create and view projects (Read)
available
available
available
available
available
available
available
not available
not available
not available
not available
not available
Access to project settings
available
not available
not available
not available
not available
not available
available
available
available
available
available
available
available
not available
not available
not available
not available
not available
available
available
available
available
available
available
available
available
available
not available
not available
not available
Assign requirements to test cases
available
available
available
not available
not available
not available
available
available
available
available
available
available
available
available
available
not available
not available
not available
available
available
available
not available
not available
not available
available
available
available
not available
not available
not available
available
available
available
not available
not available
not available
available
not available
not available
not available
not available
not available
Create, update and delete label
available
available
available
not available
not available
not available
available
available
available
not available
not available
not available
available
available
available
not available
not available
not available
available
available
available
available
available
available
available
available
available
not available
not available
not available
available
available
not available
not available
available
not available
available
available
not available
available
not available
not available
available
available
available
not available
not available
not available
available
available
available
available
available
available
available
available
not available
not available
not available
not available
available
available
available
available
available
not available
Enable access management
Note: Required for legacy projects only. New projects have access management enabled by default.
To manage users and groups, you need to enable access management in your Test Manager project. Open Test Manager and navigate to Project Settings > Manage access, open a project, click Enable now, and then confirm your action. Now you can start assigning users and groups to your organization's projects.
Manage user and group access
Note: If you have a legacy project, you might need to enable access management, to start assigning users and groups to your project.
Assign Users and Groups
If you have enabled access management, you can start assigning users and groups to your project.
  1. Sign in to Test Manager.
  2. Open a project.
  3. Navigate to Project Settings > Manage Access.
  4. Click Assign users/groups.
  5. Enter a user or group in the form field.
  6. Press Enter to add the user/group. You can add multiple users and groups at once.
  7. Click Add to confirm your action. The users and groups are now assigned to the project.
Transfer Project Ownership
As Project owner, you can transfer this role to another user. The new user can grant Test Manager access to users and groups, and perform administrative tasks.
  2. Open a project.
  4. Find the user to which you want to transfer project ownership and click the vertical ellipsis.
  5. Select Transfer ownership in the dropdown list.
  6. Confirm your action. Project ownership is now transferred to the new user.
Edit Individual User and Groups
You can edit roles or remove users and groups.
  1. Open Test Manager.
  2. Open a project.
  4. Find the user or group that you want to edit and click the vertical ellipsis.
    4.1 Select Edit roles to change the roles.
    4.2 Select Remove user or Remove group to remove users or groups.
  5. Confirm your action.
To perform a bulk operation, see Removing users and groups.
Related articles
Behavior of unlicensed users
Users invited to an organization without a Tester - Named User license can still explore Test Manager projects where they hold the Viewer role. Unlicensed users who hold the Viewer role in a project can perform the following actions:
  • Open the project.
  • Review and navigate through test objects, such as:
    • Requirements
    • Test Cases
    • Test Sets
  • Go to the Execution tab and view the list of grouped executions by Test Set.
    Note: Users who don't have a Tester - Named User license cannot open a test execution and view its details.
  • User and Group Access Management
  • Conditions
  • User roles and privileges
  • Enable access management
  • Manage user and group access
  • Assign Users and Groups
  • Transfer Project Ownership
  • Edit Individual User and Groups
  • Behavior of unlicensed users
