- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Disaster recovery: Active/Passive configurations
- Generating the configuration file using a wizard
- AKS input.json example
- EKS input.json example
- Configuring a Kubernetes Secret as a secretstore
- Configuring Azure Key Vault as a secretstore
- Installing the External Secrets Operator in Kubernetes
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Last updated Dec 5, 2025
By default, credentials are defined in input.json. To improve security, you can split the data into two parts:
input.jsonfor storing configuration values only.- Kubernetes Secret to store credentials (serves as the secretstore).
Note: You cannot store certificate paths or certificate-related credentials as part of the secretstore.
If the namespace does not already exist, create it before deploying UiPath products, as follows:
kubectl create namespace <uipath-namespace>
Note: The secret must be created in the namespace where
uipath products have to be deployed.
For Depending on how you want to manage credentials, your
uipathctl to identify that credentials are stored in a Kubernetes Secret, add the following section to input.json:"secret_store": {
"enabled": true,
"secret_name": "uipath-credentials" // Secret deployed in uipath ns with all the credentials configured.
"secret_store": {
"enabled": true,
input.json can contain either both configuration and credentials, or configuration only and credentials are stored in the secret, as
shown in the following diagram:
- The following example shows a default
input.jsonwith configuration and credentials:{ "admin_username": "admin", "admin_password": "password", "apps": { "enabled": true, "external_object_storage": { "enabled": true, "account_key": "secretkey", "account_name": "as-storage-account", ... } }, "external_object_storage": { "enabled": true, "account_key": "secretkey", ... }, "fabric": { "redis": { "hostname": "redis-cache.mycompany.com", "password": "redispassword", "port": 6380, "tls": true } }, "fqdn": "automationsuite.mycompany.com", "orchestrator": { "enabled": true, "sql_connection_str": "Server=tcp:mssql.mycompany.com,1443;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=sqladmin;Password='sqlpassword';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;", "external_object_storage": { "enabled": true, "account_key": "secretkey", "account_name": "os-storage-account", ... }, ... }, "registries": { "docker": { "url": "registry.uipath.com", "username": "username", "password": "password" }, "helm": { "url": "registry.uipath.com", "username": "username", "password": "password" } }, "snapshot": { "enabled": true, "external_object_storage": { "enabled": true, "client_id": "1fbd7d95-5f8c-4f70-90a6-fdf20310d10e", "client_secret": "client-secret", ... } }, "storage_class": "managed-premium", "storage_class_single_replica": "azurefile-csi", "sql_connection_string_template": "Server=tcp:mssql.mycompany.com,1443;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=sqladmin;Password='sqlpassword';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;", "sql_connection_string_template_jdbc": "jdbc:sqlserver://mssql.mycompany.com:1443;database=DB_NAME_PLACEHOLDER;user=sqladmin;password={sqlpassword};encrypt=true;trustServerCertificate=true;loginTimeout=30;hostNameInCertificate=mssql.mycompany.com", "sql_connection_string_template_odbc": "SERVER=mssql.mycompany.com,1443;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=sqladmin;PWD={sqlpassword};Encrypt=yes;TrustServerCertificate=yes;Connection Timeout=30;hostNameInCertificate=mssql.mycompany.com", "sql_connection_string_template_sqlalchemy_pyodbc": "mssql+pyodbc://sqladmin:[email protected]:1443/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server", "postgresql_connection_string_template_sqlalchemy_pyodbc": "postgresql+psycopg2://sa:<password>@135.235.240.165:5432/DB_NAME_PLACEHOLDER" }{ "admin_username": "admin", "admin_password": "password", "apps": { "enabled": true, "external_object_storage": { "enabled": true, "account_key": "secretkey", "account_name": "as-storage-account", ... } }, "external_object_storage": { "enabled": true, "account_key": "secretkey", ... }, "fabric": { "redis": { "hostname": "redis-cache.mycompany.com", "password": "redispassword", "port": 6380, "tls": true } }, "fqdn": "automationsuite.mycompany.com", "orchestrator": { "enabled": true, "sql_connection_str": "Server=tcp:mssql.mycompany.com,1443;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=sqladmin;Password='sqlpassword';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;", "external_object_storage": { "enabled": true, "account_key": "secretkey", "account_name": "os-storage-account", ... }, ... }, "registries": { "docker": { "url": "registry.uipath.com", "username": "username", "password": "password" }, "helm": { "url": "registry.uipath.com", "username": "username", "password": "password" } }, "snapshot": { "enabled": true, "external_object_storage": { "enabled": true, "client_id": "1fbd7d95-5f8c-4f70-90a6-fdf20310d10e", "client_secret": "client-secret", ... } }, "storage_class": "managed-premium", "storage_class_single_replica": "azurefile-csi", "sql_connection_string_template": "Server=tcp:mssql.mycompany.com,1443;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=sqladmin;Password='sqlpassword';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;", "sql_connection_string_template_jdbc": "jdbc:sqlserver://mssql.mycompany.com:1443;database=DB_NAME_PLACEHOLDER;user=sqladmin;password={sqlpassword};encrypt=true;trustServerCertificate=true;loginTimeout=30;hostNameInCertificate=mssql.mycompany.com", "sql_connection_string_template_odbc": "SERVER=mssql.mycompany.com,1443;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=sqladmin;PWD={sqlpassword};Encrypt=yes;TrustServerCertificate=yes;Connection Timeout=30;hostNameInCertificate=mssql.mycompany.com", "sql_connection_string_template_sqlalchemy_pyodbc": "mssql+pyodbc://sqladmin:[email protected]:1443/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server", "postgresql_connection_string_template_sqlalchemy_pyodbc": "postgresql+psycopg2://sa:<password>@135.235.240.165:5432/DB_NAME_PLACEHOLDER" } - The following examples show the
input.jsonwith configuration only (secret_storeconfigured) and the credentials stored separately incredentials.json:input.jsonsample with configuration andsecret_storeconfigured:{ "apps": { "enabled": true, "external_object_storage": { "enabled": true, ... } }, "external_object_storage": { "enabled": true, ... }, "fabric": { "redis": { "hostname": "redis-cache.mycompany.com", "port": 6380, "tls": true } }, "fqdn": "automationsuite.mycompany.com", "orchestrator": { "enabled": true, "external_object_storage": { "enabled": true, ... }, ... }, "registries": { "docker": { "url": "registry.uipath.com" }, "helm": { "url": "registry.uipath.com" } }, "secret_store": { "enabled": true, "secret_name": "uipath-credentials", "provider_configs": [] }, "snapshot": { "enabled": true, "external_object_storage": { "enabled": true, ... } } }{ "apps": { "enabled": true, "external_object_storage": { "enabled": true, ... } }, "external_object_storage": { "enabled": true, ... }, "fabric": { "redis": { "hostname": "redis-cache.mycompany.com", "port": 6380, "tls": true } }, "fqdn": "automationsuite.mycompany.com", "orchestrator": { "enabled": true, "external_object_storage": { "enabled": true, ... }, ... }, "registries": { "docker": { "url": "registry.uipath.com" }, "helm": { "url": "registry.uipath.com" } }, "secret_store": { "enabled": true, "secret_name": "uipath-credentials", "provider_configs": [] }, "snapshot": { "enabled": true, "external_object_storage": { "enabled": true, ... } } }credentials.jsonsample with credentials:{ "admin_password": "password", "admin_username": "admin", "apps": { "external_object_storage": { "account_key": "secretkey" } }, "external_object_storage": { "account_key": "secretkey" }, "fabric": { "redis": { "password": "redispassword" } }, "orchestrator": { "external_object_storage": { "account_key": "secretkey" }, "sql_connection_str": "Server=tcp:mssql.mycompany.com,1443;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=sqladmin;Password='sqlpassword';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;" }, "postgresql_connection_string_template_sqlalchemy_pyodbc": "postgresql+psycopg2://sa:<password>@135.235.240.165:5432/DB_NAME_PLACEHOLDER", "registries": { "docker": { "password": "password", "username": "username" }, "helm": { "password": "password", "username": "username" } }, "snapshot": { "external_object_storage": { "client_secret": "client-secret", "client_id": "1fbd7d95-5f8c-4f70-90a6-fdf20310d10e" } }, "sql_connection_string_template": "Server=tcp:mssql.mycompany.com,1443;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=sqladmin;Password='sqlpassword';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;", "sql_connection_string_template_jdbc": "jdbc:sqlserver://mssql.mycompany.com:1443;database=DB_NAME_PLACEHOLDER;user=sqladmin;password={sqlpassword};encrypt=true;trustServerCertificate=true;loginTimeout=30;hostNameInCertificate=mssql.mycompany.com", "sql_connection_string_template_odbc": "SERVER=mssql.mycompany.com,1443;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=sqladmin;PWD={sqlpassword};Encrypt=yes;TrustServerCertificate=yes;Connection Timeout=30;hostNameInCertificate=mssql.mycompany.com", "sql_connection_string_template_sqlalchemy_pyodbc": "mssql+pyodbc://sqladmin:[email protected]:1443/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server" }%{ "admin_password": "password", "admin_username": "admin", "apps": { "external_object_storage": { "account_key": "secretkey" } }, "external_object_storage": { "account_key": "secretkey" }, "fabric": { "redis": { "password": "redispassword" } }, "orchestrator": { "external_object_storage": { "account_key": "secretkey" }, "sql_connection_str": "Server=tcp:mssql.mycompany.com,1443;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=sqladmin;Password='sqlpassword';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;" }, "postgresql_connection_string_template_sqlalchemy_pyodbc": "postgresql+psycopg2://sa:<password>@135.235.240.165:5432/DB_NAME_PLACEHOLDER", "registries": { "docker": { "password": "password", "username": "username" }, "helm": { "password": "password", "username": "username" } }, "snapshot": { "external_object_storage": { "client_secret": "client-secret", "client_id": "1fbd7d95-5f8c-4f70-90a6-fdf20310d10e" } }, "sql_connection_string_template": "Server=tcp:mssql.mycompany.com,1443;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=sqladmin;Password='sqlpassword';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;", "sql_connection_string_template_jdbc": "jdbc:sqlserver://mssql.mycompany.com:1443;database=DB_NAME_PLACEHOLDER;user=sqladmin;password={sqlpassword};encrypt=true;trustServerCertificate=true;loginTimeout=30;hostNameInCertificate=mssql.mycompany.com", "sql_connection_string_template_odbc": "SERVER=mssql.mycompany.com,1443;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=sqladmin;PWD={sqlpassword};Encrypt=yes;TrustServerCertificate=yes;Connection Timeout=30;hostNameInCertificate=mssql.mycompany.com", "sql_connection_string_template_sqlalchemy_pyodbc": "mssql+pyodbc://sqladmin:[email protected]:1443/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server" }%
The credentials are stored as part of a Kubernetes Secret, as shown in the following example:
apiVersion: v1
kind: Secret
metadata:
namespace: uipath
type: Opaque
data:
config.json: 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: v1
kind: Secret
metadata:
namespace: uipath
type: Opaque
data:
The Kubernetes Secret can be created using the
credentials.json file with the following command:kubectl create secret generic <secret-name> \
--from-file=config.json=<path-to-credentials.json>/credentials.json \
--namespace=<uipath-namespace>kubectl create secret generic <secret-name> \
