- Open API
- Introduction to Automation Hub API
 - API References
 - Generate your Token from Automation Hub
 - Input for Automation Pipeline
 - Input for Submission Type
 - Input for Phase
 - Input for Status
 - Input for Phase and Status Update
 - Input for Business Unit
 - Input for Applications
 - Input for Category
 - Input for Cost Benefit Analysis
 - Input for High Level Assessment
 - Input for Detailed Assessment
 - Input for Automation Idea Creation Date
 - Input for Users
 - Input for User Status
 - User Status Table
 - Input for Collaborators
- Output Dictionary
 - Automation Hub Open API Power Query Data Parsing
Automation Hub API Guide
Last updated Apr 19, 2024
The Automation Hub API Swagger definition can be accessed directly by adding the Authentication details in the Authorization key in the request call named Header.
https://automation-hub.uipath.com/api/v1/api-doc/
The guide herein is built to support the Swagger documentation, by providing relevant and easy to follow examples.
To use Swagger documentation in Delayed Release Organizations, use the following link:
https://ah-gxp-openapi-us.uipath.com/api/v1/api-doc/
If you prefer to work with Postman, create a Postman environment. Afterwards, check out our API collection made available at this link. The collection can be imported by clicking the Run in Postman button.
